Patty Pooh
- Joined
- Apr 15, 2003
- 90
I am not getting fuel to the Carbs. I repaced Fuel Pump with a fuel pump kit, all new lines new gas tank, new primer pump with new conectors on both ends.My Motor has a sedament bowl with filter,when i prime it the the pump gets hard and i can see fuel in bowl, I will crank but no start,when i disconnect the line from the carbs it will start right up depending how much fuel i put in manually up top. I put the line from the carbs in a cup and tryed to crank it and it astarted right up but just a trickle of fuel came out of the line while it was running. With the line disconnected from the carbs when i pump the prime bulb nothing comes out, should it. Any suggestions are greatly appreciated and thank you!
