Please help if you can! I've been struggling with this stalling issue on my E70ELCIH since last season and I'm stumped. I've spent weeks reading articles on this forum and have tried the suggestions I've found ... but without success so far.<br /><br />Symptoms/behavior of the engine is:<br />- Engine idles well when cold and while warming up(both in and out of gear). Once the engine is hot (e.g. after running at high speed for a while), it will stall while in gear going at low speeds. <br />- Engine runs great at high speed (once I coax it there)<br />- Engine stalls during acceleration 90% of time. During the stall, choking the carb doesnt help and pumping the fuel bulb does not help. <br />- In the event the engine doesnt stall, the engine moves slowly towards higher rpms like it's trying to 'catch up" to itself. The rpms steadily rise although the throttle is stationary.<br /><br />I've done the following work/troubleshooting in an attempt to fix it:<br />- Rebuilt Carbs, verified proper float positioning, replaced all parts including core plugs. Verified complete cleanliness of carbs.<br />- Rebuilt Fuel Pump. <br />- Replaced sparkplugs. <br />- Verified good spark in all 3 cylinders both idling and in gear.<br />- Verified good compression (100-110 psi while trying to key-start with no plugs) <br />- Performed partial link and sync -- I synchronized the throttle and choke linkages. I verified the timing advance at idle was 2 degrees but I havent done the maximum spark advance measurement yet. <br />- Verified that timing plate is moving smoothly during throttle advance. The timing plate starts moving when the throttle is at about the "11:00 position" and stops moving when it's about at "10:00 position". <br />- Verified proper tension in throttle cables<br />- I'm using fresh gas with 50:1 ratio gas to evinrude/johnson 2-cycle oil<br /><br />What should I try next!???!? Thanks in advance for any help !!!
