unknown_sender12
- Joined
- Jul 19, 2007
- 5
Alright hopefully somebody can figure out whats going wrong so i can catch most of summer. My boat ran fine for the for about the first 6 rides, then i put a new prop on and about 2 rides after that i start having problems. As a side not i never run my boat higher then 5100(except if im trying diagnose) I got an 87 200hp envinrude. It idles great and run great at high speed. The high speed for it now is about 200 rpm lower than it used to be. My main problem is that whenever i try to get the boat to plane it will run fine up until it hits 2500rpm then it will just bog right out and start running rough. I tried pumping the primer ball and it did nothing, tried pushing the key on to engage choke and it really bogged the motor, we tried spraying premix into each carb when the motor was bogged and it had little to no effect. When i sprayed in the carbs most of the time it bogged the motor a lil or you would just hear the engine bog such a small amount that you could only slight change in sound. But when we sprayed into the top carb on the port side the engine revved up about 100rpm. When on shore i took the hose off of the outlet of the fuel pump cranked the motor for a few seconds, it delivered a constant amount of fuel and we let it pump about 8 times. I pulled all the plugs and all of them delivered a crisp blue spark and are gapped to .040. THis whole time im thinking the carbs need to be cleaned or rebuilt but im trying to avoid it. I also went on the water this evening to check the timing. In my book it says pick up timing should be 5-8 BTDC and advanced timing a WOT should be 17-19BTDC. so i took it out on the lake and my idle timing is 6 ATDC i cant even get in to go to TDC, My advance timing at 5150rpm is 7 BTDC. I played with that to and cant get it anywhere near 17 but my rpm at WOT went from 4900 to 5150, So i dug a little deeper and turn out because of some repairs back in the day i now has a flywheel off of a 86 250hp. I used a dial indicator to figure out where TDC starts and finishes. then went halfway in between, and put a mark on the flywheel, it was at about 3BTDC according to the flywheel. So what do i do.
