Stupid Clearance Light Problem
jburn25
I've obviously got some kind of ground issue with my clearance lights. Everytime I wire them up to the brown trailer wires on each side of my boat trailer it blows a fuse and only the break lights work. When I disconnect the clearance lights completely, and then replace the fuse, the running lights work fine leading me to believe it is simply a problem with the wiring of the clearance lights.
I have these optronics clearance lights: http://www.atafa.com/sports/products/Optronics_CLEARANCE_LIGHT_AMBER_MCAS-281643.html
They come with one quick connect wire that goes to the brown running lights wire. Supposedly the ground is completed with the metal tab that touches the wire that holds the light to the trailer. Should I install a separate ground wire and screw?
NYBo
Re: Stupid Clearance Light Problem
You must have a dead short somewhere in one of those lights or a pinched wire.
Silvertip
Unfasten the lights from the trailer but leave the wiring intact. Replace the fuse and now turn the lights on. If the fuse blows again, you have direct short in the hot wire to one or more of the lights. If it now works, begin adding the lights back. When you find the troublesome light, the fuse will blow. Check its wiring.
