duped
- Joined
- Aug 26, 2009
- 307
2000 Merc Horizon 350 MPI inboard. Once last year and now again this past trip I get a constant warning buzzer from my starboard engine. Both times it has happened after running at low RPM while trolling, and only after 2-3 hours of running. As I understand from the manual it is either an oil pressure or temperature alarm. I don't believe the transmissions have any type of warning switch on them, but regardless the fluid is fine on that too. Oil pressure is 40 psi, oil is clean and at the correct level, and temp about 160-165. I have never had any issues overheating, or losing / burning oil or losing pressure. Engine runs GREAT! I did stick my hand on the exhaust manifolds and they were nice and cool. Good water flow out the exhaust. Raw water pump new last summer. Coolant is clean and at the correct level.
To make matters more confusing, I have Fox marine MEFI3 engine gateways, and I pulled up the diagnostics on my phone. While this buzzer was going off, everything is reading normally. As you see in the screen captures below, temp was 161, low oil pressure warning wasn't active, nothing specifically wrong...no red flags.
The only thing the diagnostic says is "General Warning Level 2 active", which is not helpful at all.
Anyway, I shut it down for an hour and used the other engine. When I turned it back on to head in, the buzzer didn't come back on and I had it running at 3300 RPM the whole way in.
Am I correct in thinking that more than likely I have an errant sensor issue more than anything seriously wrong? I think the alarm system uses separate sensors, correct? So in theory a failed temp or oil sensor on the warning circuit could cause this while the sensors the engine computer, and gauges use is fine? I'm struggling for a better explanation at this point.
