Stupid question....anyone got a minute to spare and help?
theteacher
Bought a 1998 Stingry 220CX, 72 hours. Everything works, I think. I turn on the bilge switch and nothing happens. Does this mean there's no water, therefor no need to run ( automatic ) or does it mean it's broken. I'm sure it's just that there's no water to pump out, but how do I check it to make sure it's operable?
Thanks !
CheapboatKev
Re: Stupid question....anyone got a minute to spare and help?
Water or not if you flip her on she should run.
Since you have a switch at the helm, I assume you dont have a "float switch" to automatically come on.
Get a volt meter and check your fuses to see if its blown.
seaboo
You should hear it run but keep in mind these pumps are QUIET, listen well.
QC
You can have a dash switch AND a float switch . . .
Stick a hose in the bilge and fill her up . . . if the pump doesn't work you pull the plug. Get the bow up and go for it.
theteacher
Thanks guys, I'll do as told.
5150abf
Just turn it on and stick your ear against the hull and you should hear it run and if you don't have a float switch on it is highly reccomeneded that you get one, normally by the time you figure out you are taking on wate it is too late..
Home Cookin'
Be aware that a pump can run and not work, so the sound test is the first, but not the last, step. I had one where the shaft broke, so the motor ran, but the impeller didn't.
southkogs
+1 - This is the fast, easy check.
seasprayralph
your bilge pump switch may have 3 positions (one of my previous boats had this),, UP=manual ,,centre=off ,,down=auto,, or possibly operation positions the reverse ,, worth checking out,, a second option is to check to see if you have an automatic bilge "float" , it will operate when the water level in the bilge reaches a certain height ,to test, simply lift the float slightly ,pump should run
gstrom11
I had the same issue, took the old pump out and it was melted, pretty cool looking all melted and stuff but not funcional at all. I ordered one from iboats, had it in a day and now I hope I never have to use it!
