NealLauderman
- Joined
- Feb 12, 2007
- 191
I just got done re-wiring the boat. I tested all the accessories and they worked great. I then went to crank engine and I blew the battery fuse which was 100 amps...
I don't think there is an issue with it being connected wrong... I'm kinda thinking 100 amps is to small when cranking a 200hp engine.
Below is a quick drawing of what I am looking at. The battery switch was set to battery 1.
What are your opinions and what size are others using? I'd hate to run it without a fuse or breaker protecting it.
Here is a diagram to give a visual:
Here is the blow fuse:
