Doug Durako
- Joined
- Nov 17, 2002
- 519
Okay, boys, I have tried about everything to unplug the "built-in" speedo tube in my Alpha 1.<br />Small drill bit, wire from the bottom up, wire from the top down, forced air from the bottom up, forced air from the top (where it connects to the rubber tube) down, lots of penetrating oil, etc.<br /><br />Any other tricks? There must be a small sliver of wood in there because it is holding water in the tube in the drive.<br /><br />Do I need to crack the lower drive from the upper to get at this?<br /><br />It just bothers me when stuff does not work.
