gm280
- Joined
- Jun 26, 2011
- 14,605
For the last year now my left front tire on my lawn mower has had a slow leak. And I always just fill it up before using it every time. Well the recent post about "green slime" here on iboats got me to thinking more about it. So rather then inject the green slime hoping it solved the slow leak and also not wanting to deal with that green slime if I ever removed the tire, I decided to just buy a tube. Not a bad outlay of money, a little less then $9 dollars. So I went to my shop with the tube and removed the tire off the rim. A little struggle with a few flat bladed screwdrivers and some elbow grease and wala...off. I looked over the tube and made my decision just how that thing should go on the rim. Seems the air valve stem is a little offset to one side, or so it seems anyway. So I installed it and replaced the tire as well. So now to fill it up and seat the bead. I applied some air and it filled pretty nicely but wasn't sure how much air was in it. By this time the bead was seated nicely all around the rim. So I measured the air and it was about 8 pounds. It calls for 14 pounds. So I applied the air chuck to it again, and the stem vanished inside the rim...... OMG now what do I do. I can't see the valve stem anymore and the tire wasn't filled, but was inflated to where I couldn't easily get the tire off the rim again... I closed up shop and went back in the house...the day is over for me! Of course all types of ideas went through my head as to how I could solve that problem. Next day I was a little more fresh and inspired and tackle the TIRE from hades! I took every type tool I could think of and wanted to remove the tire without damaging the tube. Finally, after wrestling with it and even tag teaming with my wife, I pried the tire away from the rim (nearly bending the rim) and saw the valve stem wedge between the tube and rim. I was able to take a flat bladed screw driver and deflate the tube and all was well again in the world. I've since fixed that tire/tube ordeal and it is now resting in its place on the left front position of the lawn mower again. Funny how things can change your opinion of a great day some times :facepalm:
