Re: Styrofoam?
Great idea for a thread that I'm sure would not be original: Building Construction Foam vs. Marine Floatation Foam
I have heard there is a major difference in the cells of the foam and that construction foam can water log.
And we all know that marine floatation foam never gets waterlogged. ??
Uncle has had pink sheets around his pump house for years. They are actually under water.
We had to get into the box last year so we had to remove the foam.
It was not waterlogged at all.
Just as some people have used the swimming pool noodles and have tested for waterlogging issues, not a problem.
For the original poster, your Starcraft came with sheet styrofoam, as did all of mine.
The new sheet foam is better than the old white pellet foam.
I use the 1" thick foam, as it is easier to work with, and will pack into smaller spaces.
