supercoolbabe
- Joined
- Jun 5, 2008
- 103
My 1976 15hp Evinrude sunk in my canal for 10 hours. When pulled out it took 3 hours until I was able to pull spark plugs and crank out water and spray with WD-40 then put in oil and drained.. Then I removed and cleaned the carburetor blew out all the passages until there was no water left. I replaced all gasoline in tank and tubing. I changed out lower gear lube. I cleaned all exposed electrical wires and cleaned and put dielectric grease on them. AIl wires have continuity. I have spark from both plugs. I have tried putting in gas oil mixture in carb and pulled spark plugs putting in gas\oil mix, starting fluid, carb cleaner, and seafoam. I wiped down entire engine. I have blown the whole thing with compressed air at least 10 times. I have pulled and pulled it for one week now and it will not start. I only have a flywheel puller with arms not the kind that uses the three bolt holes in flywheel. Can I use the puller I have? I have not found anything except the low speed needle valve that is a little worn. The only time it seemed the motor tried to start was when I was checking spark and with no throttle. I am too poor to send to shop but I hate to give up. I worked very hard to get this motor running before I stupidly sank my boat. Any chance it will still run?
It was not running when it sank in fresh water.
