Last weekend i was at the lake and the shore was real sandy, I believe I got some sand sucked up. The water flowing out isn't nearly as much as normal.
Is there a way to get the sand out without taking the lower unit apart (I tried using the muffs to see if that would force enough water through but...), if not what should I do once I have the lower unit off, I've never had this problem before so any help would be appreciated?
If it makes a difference its an 88 125 force.
