Mainiac Boater
- Joined
- Jul 27, 2010
- 38
I have a 2001 Sugar Sand Tango with a 2005 175hp Mercury XR2 sport jet. I had the boat on the water yesterday for about an hour. While cruising at about 3800 RPM I suddenly lost power. RPMs dropped to about 2800-3000, enough for the boat to come off plane. I initially thought the throttle linkage may have come loose because I immediately brought the throttle lever to the neutral position but the engine still ran at about 2800 rpm. I continued to fiddle with the throttle lever and the engine briefly regained power only to lose it again. Shortly thereafter I heard a clunk and the engine quit. The whole ordeal probably lasted 20 seconds. I attempted to start it once but the engine would not turn over. The engine was warm to the touch but you could keep your hands on it. No warning buzzers at all. I trailered it home and discovered that the flywheel will not turn.
Did my motor just blowup? I am marginally mechanical so I would like to troubleshoot the obvious things myself. Any suggestions on where to start?
