Suggestion on how to properly wire up a new gauge
CaptainYARRR
Hey everyone,
One of my gauges broke and unfortunately, Livorsi can't fix the model of gauge I have. So I had to buy this new style that's a plug vs. the current ring terminal. If my connection had just three individual wires going to the gauge, I'd do a butt connection and I'd be done.
My issue is that one of the connections has four wires that would need spliced together. Originally I was thinking I'd just run a small bolt between all the ring connections and cover it in electrical tape. Livorsi said it was a terrible idea, so my question is, what's a clean and safe way to wire this up?
Essentially my issue is needing to splice a plug pigtale in to as many as four wires. Any suggestions? See attached photo. Each post's connections are cable tied together.
poconojoe
Yeah they are right, don't bolt those ring connectors together. Cut the ring connectors off and use insulated barrel crimps to join the wires. I would also heat shrink over each connection for better protection.
poconojoe
If you need to join two wires together, it's best to use the barrel crimps. It's also called butt splice.
Those stackables are good if you need more than one connection on a male spade blade. They are not meant to splice wires.
CaptainYARRR
Yes that's the reason for the post, I need to join four wires that were previously attached to a single post. Butt connectors are super straightforward, I wish that's what it needed!
