accentphoto
- Joined
- May 4, 2011
- 128
I have a 1984 90hp Mercury that I am getting ready to replace all of the electrical components on and I thought that before I committed to actually putting them on I would open the motor somewhere to see if the aluminum block had corroded badly from salt water use and the PO not flushing properly.
Any suggestions on where I should check? Which side to open? I have the electrical mounting bracket that holds the switch boxes and coils already off and the frame that goes around the top of the engine is off. I have about 90% access to the starboard motor side bolts and 95% on the port side. Since I can't find my Mercury repair book I thought I'd ask. I just want to make sure the insides are not corroded away.
So I think I am looking at removing either the exhaust cover, cylinder block cover or the (for lack of better words) starboard side behind the electrical mounting plate side.
Also, how do you get to the lowest engine cover bolts if they are in the bottom recesses of the bottom cowl? Does the cowl somehow slip over the motor and if so, what needs to come off?
