22E6441
- Joined
- May 29, 2008
- 376
For two months I've been going crazy trying to get my boat fixed. This started back at the end of May, when my boat started sputtering or misfiring under load. I could not get the boat to go more than quarter throttle.
http://forums.iboats.com/showthread.php?t=315581
It was suggested that I got some junk in my carbs, so I picked up and installed some carb kits. Here are all of my pictures from the rebuild:
http://forums.iboats.com/showthread.php?t=338495
Before I actually got it running again, I blew a fuse a couple times. It's the red inline fuse under the electrical cover. There is a picture of it in the next linked thread. I figured I was blowing it because I didn't open the primer to help prime the carbs. I did so, then it worked great. Took it out and had the same problem again.
http://forums.iboats.com/showthread.php?t=325736
It was suggested that I do a link and sync. I figured that the procedure was a bit beyond me, and I don't have the tools anyway (like a good timing gun). So I took it to the shop and had a bit of work done.
http://forums.iboats.com/showthread.php?t=332959
I'll post some important comments from the other thread here for convenience:
As noted in that thread, I took the boat back to the shop but the mechanic was off. Another person there suggested that it might be something like bad o-ring in my tank or line. I had an old steel tank and old gas line from the tank to the motor, so I figured what the heck and replaced them both.
I took it out for a test run (a short run due to lousy weather) and it seemed to be OK.
Took it out again the other day when the weather finally turned nice....no love. This led to a series of posts, starting with:
http://forums.iboats.com/showthread.php?t=340321
Then trying to figure out what SLOW is, and if that has something to do with my engine.
http://forums.iboats.com/showthread.php?t=340435
http://forums.iboats.com/showthread.php?t=340431
So, this is where I'm at now.
Had the boat out today. Started perfectly. Idled perfectly. Left the channel no wake speed perfectly. Started to apply throttle...BINGO! Got on plane quick and easy...seemed perfect....then BLAMMO. Chug chug sputter sputter misfire. Back off the throttle and it runs perfect again.
Like I mentioned in a different thread, I disconnected the wire to the temp switch, it made no difference.
I tried the boat a few times, always waiting about ten minutes between tries and disconnecting my negative battery terminal before starting again. Same thing kept happening.....up to 1/4 throttle and "chug sputter misfire" herein after referred to as CSM (Chug Sputter Misfire).
Some observations:
1. The engine does not seem overly hot. I can easily put my finger on the block for a 1-2-3 count.
2. The thermostat housing seemed hotter than other parts of the motor, but not much.
3. The engine is peeing strong. This to me means good water pump and impeller, because if one of the two were not working well the stream would not be as strong as it is.
4. The temp of the stream is fairly cool, but feels a bit warmer intermittently at idle after it starts doing the CSM. Again, the shop said it was coming up to temp and working properly.
5. There does seem to be some blow back out of my carbs evidenced by some gas seeping out of a hole on my air silencer, but I don't know how much.
So, with the rebuilt carbs, new lines and new tank, I'm relatively certain that it is not a fuel problem. Also, pumping the bulb makes no difference.
It's not the temp switch, since disconnecting it made no difference.
The motor ran well in the shops test tank with the test prop wheel thing. This is an authorized and reputable shop / dealer.
I only wonder if maybe they didn't run it for long enough in the tank for it to start acting up.
Again, when I took it out today it seemed to be working right. After a couple minutes the problems started.
I think one of the best suggestions so far is maybe a bad coil. This is an intermittent type problem though.....
Here's one of my videos:
http://www.youtube.com/watch?v=DKbWcw2JRY8&feature=related
So, if you're still with me this far into this thread, or saga might be a better term, I would really appreciate some advice or thoughts.
UPDATE:
A couple more ideas from people in my other thread:
.Comments from mechanic:
Carbs look good
Set up idle mixture screws and throttle plate
not coming up to temp
found loose seat and old seat from thermostat still in motor
removed old seat and installed other seat properly
shifting and cooling ok
idle and throttle advance ok
motor starts and runs well
Also made a note that my temp alarm isn't working. he said that the temp alarm is separate from the vro oil alarm. I thought the temp alarm didn't work becasue the oil side of my vro was disconnected and I thought the alarms were all connected
Some observations:
UPDATE:
Check the wires from the stator to the powerpack, sometimes they rub the bracket that holds the powerpack. Check the powerpack ground.
Take a timing light with you and check fire to each cyl, if firing ok check carbs.
