Keith7481
- Joined
- Aug 21, 2005
- 125
Hi all,
had to switch mechanics at the end of last season and had a new guy winterize. I called him today to double check on his process and it doesn't sound like he did any lubrication as my previous guy did. While I'm going to consider looking for a more thorough mechanic, I'm also going to consider doing the summer prep myself. Am mostly concerned about lubrication points. Have a 98' OMC with GM motor and Volvo outdrive which I had rebuilt (was found to be problematic during regular maintanenc) two years ago and I've checked the drive fluid regularly, no problems. I found a zerk fitting on the starboard side of the outdrive near the transom which I expect is for the gimbal. I'm wondering if there are other difficult to see/find grease fittings in the engine compartment. Other regular lubrication points I should consider?? As always, comments are greatly appreciated. Keith
