Leon heims
- Joined
- Sep 5, 2009
- 9
i have a johnson 90hp with 4 plugs. should i use 2 stroke oil or 4 stroke oil , im not shure which one i should use. thanks
JB has it exactly right! Get an owner's manual for sure and a service manual if you plan to work on your engine. Suzuki made a 90 4 stroke which I believe had the plugs all in a row top to bottom and it was Johnson badged. If you have two plugs on each side of the rear and a v-style engine, it should be a two stroke cycle engine. Put up a model # and get a manual or manuals factory only, no after market junk.
Okay. Whew!!
Tashasdaddy's advice is right on then.
