askiopunk4358796652
- Joined
- May 26, 2003
- 13
Ok- stupid teenager trick... I sunk the motor (it came off the back of the little boat) when I was in HS doing water "brodies". Yaa, real bright I know. Now I'm paying for it since I want to take my elderly father fishing.<br /><br />The motor sat underwater for about a month I recall. I believe when I pulled it I dumped out all the water and pulled the plugs and maybe tried to start it (no luck). It's been a *real* long time.<br /><br />There is good spark, and seems to be good compression. Everything works very smoothly and there is no binding or noises or anything. All in all you cant tell its been in the drink just by looking. <br /><br />I put in new gear lube and am getting another plug and a fuel tank and primer line.<br /><br />Anything else I should do before I try to fire her up? I've looked through past posts and have seen both views from "you HAVE to rebuild or its junk" to "clean her up and she'll be fine". Which is it?<br /><br />If I don't go with a rebuild will it be a sudden stoppage because of the rusted bearings and such(leaving my father and I stranded in the lake) or go rather gradual giving me time to make the decision later to rebuild? The motor probably won't see more than about 10 hours a year of use.<br /><br />If I do a rebuild what am I looking at for costwise and is it worth it for this old of motor?<br /><br />Thanks so much folks!!!<br /><br />Joa Harrison<br />Coeur d'Alene, ID<br />1967 Merc 5hp 2-stroke outboard (SN 2146833)
