Sure Lube Seals and Greasing Procedures
I've been faithful the last couple years in keeping my boat and trailer in good condition. This year I had the impeller, oils, and spark plugs renewed on my outboard. But the trailer thing is driving me nuts. Last year I had the local dealer replace the bearings and seals on my Karavan trailer using thrifty cardboard shrink wrap pack bearing kits cause I busted one of the seals on my hub by pumping grease into my Sure Lube axle. I didn't dare grease the bearings. After reading my manual and reading forums off other sites, I decided to attempt to grease again before beach trip. Using a 3 oz grease gun and slowly rotating the wheel, I pumped in grease slowly, some but not a lot. After traveling 250 mi and back, I discovered a seal rupture again :facepalm: Do those thrifty bearing packs have single lip seals? I read somewhere that I have to use Transcom brand seals when dealing with the Sure Lube system. That true? I bought some double lip seals from Northern Tool. What is a fool proof way of greasing a Sure Lube axle?
sea_goin_dude
Re: Sure Lube Seals and Greasing Procedures
Dude, there's not that much difference in single seals and multi seals, the seal itself just has multiple seal lips on it so it basically does the same thing.
As for lubricating the bearings. Look at the seals job, It must be able to hold internal pressure in order to keep the lube in.... well, normally the only pressure trying to push that lube out is from the lube being heated and expansion, too much lube to start.
So, before you add more lube, there must be a loss of grease or you have to remove the old lube. If you just add more lube without removing some,,,,,,,WALA you have created an overpressure and that pressure has to go somewhere. The seal isn't intended to hold much "real pressure" but to just contain the normal lube and keep it from leaking out of the hub.
Electrical motors, if you have ever noticed, or the ones that have lubeable bearings, also have a removable plug that must be taken out if the bearings are lubed. The motor runs for a few minutes and the extra and/or contaminated lube will beforced out of that "vent" hole. The plug is then replaced after extra lube stops comeing out of it. The bearing is then properlt lubed and the bearing will work for many hours as it is supposed to. NOW, IF THAT PLUG ISN'T REMOVED and the bearing is lubed anyway, everything appears to be fine but when the motor starts up with the added lube, pressure builds up and, guess what?, the extra lube is forced out throught the seal on the inside and while you can't see it, it will damage the motor and may cause it to burn out.
NOW, I do not know why these companies that make these bearings and hubs do not drill the hubs and install the same kind of release plugs so that when you do lube and try to maintain your expensive boat and trailer, Then you could add lube and permit any extra to escape, thus there will be no buildup from the extra and ultimately cause the seal (which is so small and not strong at all) to be pushed out and ruined. It would be so simple to modify these hubs (or maybe you could do it yourself) and prevent this damage which can't be prevented if there is no outlet for this additional lube,pressure. Just drill into that hub in a easily reached place and put a threaded plug in there. WOW SO SIMPLE and would save you and others from so many problems. If there should be water in the lube, if you pump new lube in SLOWLY and let the old contaminated grease to escape, and turn the wheel on the axle for a few minutes, (with the plug still out) any extra lube will come out, just like the electric motor bearings and you will save your bearings and also prevent damage to those seals, (that cost very little) but can be so expensive and time consumming to replace if/when they are blown out.
sea_goin_dude
Whisker I looked up the (Reliable Sure-Lube Trailer Hub) At Northerntool.com. If you do in fact have THIS HUB..... you should not have any problem blowing out the seals.. As I stated above in the other reply, there must be a way to relieve the extra lube or over-pressure will blow out the seals. There is no way to prevent seal damage if there is no relief for this lube !!!!!!!!
The (Reliable Sure-Lube Trailer Hub) Does provide this relief and looks like the best hub you could possibly buy or use on a boat trailer. Go to the link below to read about this axle....Reliable Sure-Lube Trailer Hub.....This is the only one i found to provide excellent provisions to give you the best protected hubs and safest design to protect your bearings. I was not familiar with these hubs but they do provide the protection that I suggested above, that permits you to lube the bearings without having to remove the hubs and clean the old grease out. Glad I saw your questions and looked it up so NOW I know that there is such a product available. Sure looks great to me.
So, if you have these axles/hubs you should have no problems, if not I'd check what you have and see if somebody may have misled you into buying theirs.
Go to the following link to see/read what I found about these super designed hubs. NOTE: The article also says NO LONGER AVAILABLE. Not sure if that means that Northern tool doesn't have them or they are off the market all together. It would be sad to lose what looks like a genuine real good desighed product.
I will look for more info and see if indeed this product is still available
AGAIN THE PRODUCT NAME IS.....Reliable Sure-Lube Trailer Hub
http://reviews.northerntool.com/039...hub-4-on-4in-model-125006-reviews/reviews.htm
This should be the diagram of this excellent hub: it clearly shows a passage for additional lube to escape, thus preventing excess pressure building up and blowing the seals.
NOTE: I did find this "sure lube" grease cap. This is only a cap with a zerk fitting in it permitting lube to be pumped into a bearing.......using this will let you pump all the lube you want into a bearing but you still need someplace for that EXTRA lube to go.
I hope I have provided some useful information for a lot of folks. I taught industrial maint for Ga adult/technical ed for 10years so enjoy trying to solve tech problems :cool:
burp
If it is infact a Reliable Sure-Lube hub, the extra/excess grease should exit on the back side of the torsion axle. There should be a small hole that the grease is expelled from. If the old grease has dried and hardened in the hole, it could be the source of your blown seal. Use a small nail or piece of wire to make sure the hole is not clogged with hardened grease. There is no need to jack up and spin the wheel when greasing the hub.
I've run the Sure-Lube hubs on my trailers for 12 years without any blown seals or bearing problems and have yet to pull a hub for repacking. Sure-Lube definitely helps minimize trailer maintenance. 3-4 pumps of the grease gun several times a year is all that is needed.
thanks for the imput guys, but its actually a spindle lube system like the EZ lube system not a hub based system.
BaileysBoat
Check the seals. By design it's impossible to pressurize the hub & bearing with the spindle lube system.
sea_goin_dude
Roscoe ...... I hear you on the banjos ha ha I live i GA/Ala so I do hear a lot of em..
Looks like we are looking at two great systems to protect our bearings.
Just be sure if you use either of these, apply the lube slowly to let the excess get out or you will blow the seals and NEVER use a power lube gun like you find in service stations / shops etc. as they will inject the lube faster than the extra/old lube can get out and, again, you will blow the seals. TAKE TIME FOR THE SYSTEM TO WORK AS IT IS SUPPOSED TO. That grease is thick and moves slowly, especially when cold.
NOTE: this has been a very informative and interesting site for me as I learn something new every day or so.
BoatNoobie
i have the surelube hubs on my 2005 Lowe trailer. I've only owned it for 1 year, but it appears to work great. I flushed out all the old grease last fall for winterizing. The old grease was pushed out no problems.
A quick search shows you can still buy these hubs from Overton.
dubldown
Use seals that are doubl lip and has a backer spring o n the inner lip.
robert graham
How can there be a problem with the Sure-Lube?...You pump new grease in, the old grease comes right back out so you can wipe it off, replace rubber seal. I pump mine just a bit every time I launch just to be darn sure no water got in. 1999 model trailer, no problems so far!
Kit Carson
I found this forum doing a search myself for information about Sure Lube spindle and hub systems. I honestly do not think there is any fool proof way. There are basically two styles of this kind of system, one has a hole drilled in the spindle and the grease travels from the front axle spindle zerk and exits at the rear of the bearing between the bearing and the hub rear grease seal. The other has the zerk on the hub itself at the rear and also the grease enters the hub assembly between the bearing and the inside hub grease seal.
Quite simply they are a real pain to deal with. One can hear all kinds of stories on forums and convince oneself that you really do not know something. When basically they are a problem. When you add grease according to all the hype one hears and sees about such products the grease is supposed to force itself from the rear of the hub, through the rear bearing, fill the hub space and push through the front bearing to indicate the hub is full of grease. Hence supposedly you are supposed to be able to force new grease through the entire hub assembly to replace the moisture laden existing grease.
It has been my experience in the 59 years of life going fishing three times a week, and dealing with all kinds of boat trailers and bearing systems, and being lined up wrong with the stars that these systems do not work as advertised. Even with a manual grease gun and carefully turning the tire to try to work the grease through the bearings the rear seal will blow out of the hub with very little grease added, let alone trying to replace all the grease in the hub. It is simply what they do. The reason is simple, all that grease flows into the hub assembly between the rear grease seal and the rear bearing and has to force its way through the hub to the front bearing and remember there is also an axle washer that covers the front bearing for the most part and leaves very little space for grease to exit to indicate to you that you now have new grease in the hub.
I do not care if you use super, duper, engineered wonder grease seals and the temperature is 80 degrees if you try to push all the old grease out as advertised the rear hub seal will pop out of the hub.
So I quit trying and simply repack the bearings by hand once a year, fill the hub with as much grease as I can pack in there by hand and also fill the dust cap that covers the front zerk full of grease too to help keep water from coming in past that rubber cover. You really have to keep and eye on that rubber cover as it becomes weather checked and so on and does allow water into the hub. You can clean the dust cap off real good and use brand new rubber covers with some silicone sealant if you like.
To make it short, I have found that these style hubs are made to aggravate the fisherman, and are designed to pop the hub grease seal out if you do try to do as advertised and push all the old grease through the bearings and past the front axle washer, to accomplish this without popping the grease seal is about like the odds of winning the lottery.
So I just hand pack the bearings once a year, put as much grease as I can in the hub while working on it, and use new rubber dust plugs, caps, whatever you want to call them with a bit of silicone sealant once a year.
We as humans try to invent all kinds of ways to do things the easy way, but it never does work as planned. With boat bearings and seals, the best way is to do it the old way and pack the bearings by hand, keep a good new hub seal once a year and occasionally put your hand on the hub while towing and if one is getting hot, at the first opportune time rebuild that one.
I am not impressed with Sure Lube systems, and never will be. As far as I can tell they are designed to pop the grease seal. I suppose one could tap the seal in just a smidgeon past flush and use a small round punch and peen the hub over the seal a bit to hold it in there. Then each time you did need to work on the hub just file the peen indentations flush before installation of a new grease seal, then peen that one in also.
I registered just to comment on this subject. As yesterday in 70 degree weather I did just what I just stated I peened the seals to the hub. I hate working on the bearings and messing with that grease. A whole box of shop rags is required. Lol!!!
Anyways I put the new grease seal in there, and carefully, very carefully pumped five pumps with a grease gun(manual) and turned the wheel, five more pumps, and turn the wheel, five more and turn the wheel, and just as I saw grease just start to come past the front bearing past the axle washer.........you guessed it pop goes the rear seal. AAARRRRRRGGGG, so I took the wheel off and this time used a round punch and peened that thing in four places and it stayed put.
Time will tell, if this invention of necessity works. I plan to add about ten pumps of grease with a manual gun once a month to keep new grease in there and push out the old moisture laden grease that is always around the front bearing where water gets past that dust cap.
It only took me 30 years to come up with punching the hub to retain the seal. Just a little, enough to keep that thing from popping out and you look under there and cry...............
roscoe
Sorry for your seal issues over the last 59 years.
Fortunately, I have not had any trouble keeping my seals and hubs working as intended and designed.
I hope you are using Kimberly-Clark shop rags, as I have stock in the company. :)
GA_Boater
Too bad you didn't read any rules when you registered. This thread is over 2 1/5 years old and you should not be posting in it. But you feel better now.
Kit Carson
Good Murnin...........:) It is 24 degrees here today and those girls might get cold. Lol!
Perhaps it is luck of the draw. I have ran across several WESCO boat trailers that have had the Super Lube spindle drill hole exiting directly under the very middle of the actual bearing. Yes quite so, so one has to put the aftermarket Super Lube hubs with the zerk on the hub on that situation or some other adequate solution, or just purchase a whole new axle with spindles. One of them also had weld spatter all over the spindle that was not cleaned off and smoothed. So naturally as fast as a grease seal was installed it simply ate itself up in the first 20 miles. A file, some emery cloth and a set of bi-focals and a strong light took care of that.
As for those shop rags, I will keep that brand in mind if I so happen to run across them. For boat bearing work I like those throw away plastic gloves and those blue rags in a box. Get yourself a big trash bag and open it up and toss the paper rags in as you go. For cleaning all that built up grease off the inside of the wheel rims I use plain ole WD-40. Soak it down and wipe it away.
Perhaps some of the problems are also beyond the control of the average person. Just like the guy who buys a trailer with the drilled grease channels that exit directly under the rear bearing surface I am quite sure that even good metal body seals may not be made to the correct tolerance to have enough direct compression friction against the hub to keep them from popping out while grease is forced through the rear bearing, through the hub and out the front bearing past the axle washer.
There seems to be a great variance in the quality and workmanship of various situations one runs across. So some of these problems experienced by those of us who do experience them are due to improper procedures and poor quality workmanship and improper tolerances of replacement parts. However good metal body seals of the proper brand name should be reliable enough to function, sadly they are not at all times.
In all walks of life products have problems. I am myself self employed and have found some products that are best avoided due to the conflict and customer situations that they create. It matters not whose fault it is, only that you were the one who used and installed that product. Warranty, smiles and handshakes are not worth a lot when a product fails to function as designed and the customer is in a panic beside the road with a wheel seal hanging on the axle or their brand new water heater floods the house due to a bad weld.
Tell those girls it is cold today. :)
Kit Carson
Yes Sir Admiral Sir!!!!
Perhaps an outlook not purchased by advertisement and personal concerns would be welcome by the ordinary feller who happens to own a trailer and wished to do the work himself or try to understand reasons there are problems?
Such as where have you ever seen a warning on aftermarket seals, such as those made of plastic with rubber coatings that ......Warning these seals are not functional with such as Super Lube systems........when one can push them in the hub by hand the light bulb should come on........however even with proper metal body tight fitting seals properly installed also have problems due to tolerance of the seals and or maybe the hub.
Are not some threads kept for knowledge and discussion for new members whom wish to actually gain a well rounded education is some subject? Are we not inventive and do we not devise ways to make products work such as I did with this particular set of trailer hubs? Or are we to blindly accept it is all our own fault?
I apologize to all for not following the chain of command and no showing proper military respect.
