tater76
- Joined
- May 7, 2010
- 712
Just another quick question, my 1973 55hp Chrysler that now has ignition from an 1985 50hp Force will not run with surface gap plugs. I have tried several different brands and numbers, but it gives me grief. When I install a new set, it will start up and idle fine for about a minute or so, then it will act like it loses spark in one cylinder. I can then install a new set of NGK BR6HS or L82C Champions and it starts with barely a tap on the key, idles smooth, and runs out great. Frank A told me to be cautious about possibly melting a piston with the non surface gap, so I am a little worried. I have had it out on 5 trips this year with approx 20hrs of solid run time. I have not seen any damage from the electrode style plugs? Will timing effect the ability to fire a surface gap plug? and am I reducing my power output from running the non suface gap plug? Any insight is much appreciated
