Surging at half throttle
BBetthauser
Boat fires up fine and idled great. But once it get up to almost plane af half throttle it starts surging hard. I thought bad fuel so drained the whole tank started fresh, replaced the plugs and wires cleaned the air flow and put a new water fuel separator on it. It did have a melted exhaust flap that was still working but replaced. Had it in 2 separate shops with excellent history of repair but even they couldnt figure it out. Thinking possibly electronic now. Any ideas if this has ever happened to anyone else before?
Assuming its a Mercruiser because its in this section, but what motor, year , serial number?
Need something otherwise it might be a chain saw :rolleyes:
BBetthauser
Whoops thought that Info was in there when I wrote it out. It's a 1995 four winns with a 5.0 cobra inboard. 220 horizon. Serial number I dont have at the moment.
achris
More fish than mountain goat
... cobra inboard. ...
Shouldn't you be in the OMC sub-forum?
If it is an OMC Cobra, let us know, and we'll move it over there.
Chris........
iboats moderator.
EDIT: Just found your other post, in the OMC section, on the same subject... As it's an older thread, I will leave the 2 separate. I have now moved this across.
Ayuh,..... Carbed, or Efi,..??
Surgin' is usually a fuel delivery issue,....
