I have a frankenstein 5.7 gi carbureted (Edelbrock 1409) replacement engine in my Pursuit. The carburetor was replaced last year. I am getting a small surging at low rpm. The idle is set around 600 but it jumps around 30-50 rpm. Gets particularly noticeable when cold leading to engine dying sometimes. This small surging persists all the way to ~1200 rpm. Should I be concerned? How stable would you expect these engines to run? I tried looking for a vacuum leak spraying carb cleaning fluid everywhere - nothing. Cleaned the carburetor twice. The ignition is solid. My next step is to do a full carb rebuild. Any other suggestions?
P.S. Needless to say, tried idle mixture adjustments multiple times, cannot get the surging to go away.
