Susuki DT 65 wont run in gear
fisherman0290
motor runs great in N, but dies out when put in gear.Looking for the answer to this problem. Thank you Jimmy
bossee
Re: Susuki DT 65 wont run in gear
Hi,<br />If You press the fuel bulb when you put in gear, does it help?<br />If it does help it is most likely a fuel delivery problem.<br /><br />Make sure the rpm is about 650-700 (when in gear). Probably around 800 rpm in neutral then.<br /><br />Make sure it runs correct on all cylinders and have correct spark plugs (NGK B8HS-10 with gap 0.31-0.35 in/0.8-0.9 mm).<br /><br />I would personally suspect the fuel pump (rubber diaphgram set). It does not cost much and is easy to replace. Check brownspoint.com<br />Could also be a carburator problem, hard to say.<br /><br />Check whole chain from tank to carburators for any suspect fuel restrictions or air leaks (in fuel connections for example). Also make sure the fuel bulb is OK (stay hard after pressing it and is mounted correctly).<br /><br />/Bo
fisherman0290
Thank's BO<br />I have checked all fuel delivery and all is well,I am at the flow meter now and i am sure this is part of the problem the lower cylender was full of sediment and i think this was causing the CDI to limit the motor to just the abilitly to limp along in idle.So I am going to be working this angle for a little while.Some of the bolt rang off so out comes the easy out.fun fun, fun.I would rather work on it, than to work for it.thank you again
