Ran into a suzuki df40d 2006 that has an idling issue. It idles fine for about 30 seconds then dies off. I changed all the fuel filters and fuel lines thought it fixed the issue. The motor was running good. I got a call and said that the engine still dying at idle, took off all the iac lines and cleaned them and made sure there were no blockages in the air lines, everything was fine idling good. I went to take it for a test run and put the cowl on and not 30 sec later the engine died. At this point i was thinking that the cowl was pinching an air line or was causing an electrical short of sorts. Found nothing checked all my wiring and there were no issues nothing was even close. The engine would die when i held the cowl 1/2 the way on. But if i left it off it ran fine. Other than a failed iac what would or could cause this to happen? Anyone had this happen to them before or ran into it. Any help would be appreciated.
