suzki dt 200 cooling problems at idle
Pickingsix
1985 dt 200 good water pressure at wake speed,but no water pressure at idle alarm sounds.
Kiwi
Re: suzki dt 200 cooling problems at idle
Sounds like it might be time to have the water pump impeller checked/replaced.
Spidybot
And check the thermostat while you're at it.
Pickingsix
Thank you Kiwi for the help on my motor.<br />Now if I can just get the impeller shiped.<br />we dont have a suzuki dealer in alabama.<br />By the way I had to change the head gaskets. <br /><br /> thanks Pickingsix :cool: :)
Pickingsix
Thanks UU<br />It was the impeller.Haveing trouble geting the new one.Had to replace the head gaskets also. :cool: :)
wilde1j
Don't just replace the impeller if there's any doubt about the pump body/liner and wear plate. Any scoring in either is cause for replacement.
