Suzuki 115 4stroke outboard missing and poping
Fishn30
Help any one! I have a 2013 Suzuki I am a commercial craber and I put a lot of hours on my motors. I recently replaced my high pressure injector pump and on test run every thing operated properly. The following day I took the boat out and shortly after running I lost 75 percent power with much miss. I nursed the boat back to the dock checked my fuel filters all clear.fired the motor back up it seemed to at first seem to accelerate properly but then dropped out again seeming to miss and sputter and pop. I again I tried to run the motor at first 1/4 of throttle it seems to want to take off then drops out sputtering and poping. On several different attempts it would open up for a few minutes then once again drop out. Almost like a coil pack heating up and breaking down or a censor going out. I do not have a code reader to diagnose it any suggestions on trouble shooting
Fishn30
ok thank you. i realised i missed the high presure fuel filter witch was pretty dirty. i cleaned it and it acting a good bit better but still acting up a bit. i also belive im getting a reading on the map sencor that needs to be adresed.
