Suzuki 2 stroke 25hp
greenhead1984
Trying to remove the oil injection system from my 1993 3 cyl 2 stroke 25hp suzuki. Took out the driveshaft on the oil pump and put the oil pump back on, removed the oil tank and capped the oil tank tube, but can't seem to figure out how to override the electrical safety shutdown to 2 cylinders when the oil tank is low. The motor runs very well for 30 seconds then shuts down to 2 cylinders, until you shutdown and restart the motor when the computer resets and the motor once again runs for another 30 seconds then shuts down again. Is their a way to connect some wires and override this?
Thanks
