Suzuki 65hp prop
Tarrif2
Hi All,<br /><br />My engine is currently being repaired in the engine repairer's but when it is done i would like to get a little bit more top speed without the expence of buying a new engine, <br /><br />Could someone please point out the prop sizes that i can use on this type of engine. i dont know what size is on at the moment. <br /><br />How do i measure the current prop size? <br />Is the size stamped on the prop?<br />What would you advise me to change to?<br /><br />Thanks
Tarrif2
Re: Suzuki 65hp prop
Sorry gut's, just another part i forgot to ask is, could you please give me a clue as to how i wire up a rev counter, i have got wires coming out of my controls but dont know what do to.<br /><br />Thanks
JB
Moving to Prop Forum.
bossee
Hi,<br /><br />This is the Suzuki orginal props (aluminium) that shipped with the DT65 when it was new:<br /><br />
<br /><br />Rule of thump: 1 inch change in pitch change RPM about 150-200.<br /><br />If You have a Suzuki prop then it is marked on the prop what diameter and pitch it has.<br /><br />You need an electrical wiring diagram for Your DT65, then You will know how to connect a tachometer. For example Clymer Suzuki Outboard Shop Manual 1985-1991 has wiring diagram.<br />What Year is your DT65?
