I'm trying to pull off lower unit for the first time and it gets stuck after about 1/4 of inch. I did remove clutch shaft nut and separated the clutch shaft from the clutch rod. Did I forget to remove something else, or do I need to ply (force) it to remove it ? All book says is to remove 9 bolts and separate the gear case assembly from the drive shaft housing. Is there a trick ? I didn't want to force it and break something before checking with someone.
Any help will be greatly appreciated. Ron
