Suzuki BF25A 2016, never seen a single drip of ethanol. But I run it for duck hunting, cold, very very wet conditions, slush and snow..... today was out on the big lake, running half speed, engine started to sputter and died, looked down and the fuel line got knocked off at the tank connector (big clumsy waders on feet). So the tank connector was in or at least close to, water in the bottom of the boat. Motor restarted and died about 15 times... then finally fired less and less until no firing. Does not fire now, just turns over and over.
Am I correct in assuming it ran out of gas when th eline got knocked off, and sucked in some water from the bottom of boat? I know how to drain the lines, do i have to disconnect the injectors to clean it out? Now that I'm back home in the garage (after getting towed in) should I just keep trying to start it and see if it works the water out? Or could there be another problem I am not seeing....
Many thanks to all in advance for help!!! And have a wonderful New Years Eve!!!!!
Thanks!
Thanks!
