after turning on key switch the temp. and check eng. light does not come on but the oil and rpm light comes on I have twins so I changed the gauges out lights work fine on other eng. so the gauge is not bad the alarm seems to work but not the light with the eng running I can disconnect the battery cable and the alarm will go off but the light dose not come on. I don't know what to do to make the temp. alarm go off.
