Suzuki DF60A Throttle body.. Is this fully open when in WOT???
Gaha
I have Suzuki DF60A 2022 on 17ft fiberglass fishing boat which weighs around 1,100 that struggles to get on plane with full tank of gas (20 Gallons), a cooler with ice, and two adults weighing close to 200lbs each. I have adjusted the engine mounting two holes up with a slight improvement. Someone recommended to try a different pitch prop, which is on order. Today, I decided to verify if my throttle body is fully open when in WOT. I noticed that it still had about 20% before it is fully engage to top pillar.
The first picture is throttle body in Neutral while the second one is in WOT on top mount binnacle.
Note that there is still some clearance to upper pillar. The video confirms that it can move further up after removing the cable.
Is my assumption correct or it should have that clearance? If so, it may be one of the reason why boat struggles to get on plane as it is not fully open?
Any help is greatly appreciated!
  • WOTvideo.mp4
dingbat
Means nothing….is the butterfly valve fully open?
That’s a heck of a load for a 60 hp motor…. Last 17’ boat I was on had a 115hp on the transom
99yam40
I agree, what HP motor is the boat rated for?
what prop are you running?
is the trim set all the way down when trying to get on plane?
Gaha
Yes I agree, boat feels sluggish. I'm not sure if the butterfly is fully open, as I am just inspecting visually from what I can see. Based on position of throttle body on WOT, there is still some leeway for the butterfly to swing a bit more. Just wondering if someone who has a suzuki motor can compare how far the WOT is on there side.
Gaha
How did it run for you last season ?---What happened ?
It was pretty much the same, no change just worked with what I had. A mechanic suggested to try and adjust the mounting hole as it was originally sitting a bit low below the transom from the factory. Another suggestion was a prop with a lower pitch. I'll be testing the prop soon when it arrives.
Gaha
It was rated for 40-60hp. The prop size is an 11.6x14 and trim set all the way down and slowly move up as I pick up speed. The boat can plane when I'm alone or after a long day fishing with another person when most of the gas and ice melted. Top end speed with two person as in low 20's.
99yam40
what RPM is the motor hitting at WOT with one person and with 2
Here is a performance bulletin for a F60Yamaha, I guess it would be similar.
Gaha
I can get to about 6000 rpm alone, but this was a run I did once. most I got on two person with gears and half tank of gas is 5300-5500 at a speed of 20-23 MPH. 4 people no gear, just cooler with drinks, ice and some food, it will not hit 5000.
dingbat
If that is the case you are way over propped. Should be able to get closed to 6,000 with your “typical” load
Gaha
Yes i absolutely agree. I ordered a Solas 11.6x12 to see if there’s an improvement.. I’m also looking at getting a 4 prop to test, heard they plane easier and lift the stern.
dingbat
The 2” drop in pitch will get you roughly 200 rpm
Four blades are great for pushing or pulling lots of weight at reduced speeds and reducing “blow outs” when running in slope.
Problem being, they waste a lot of HP due to their inefficiently at the top end. The last thing you want to do is put a 4 blade on an under powered or overloaded boat.
99yam40
I thought it was 200RPM per " of prop pitch change.
he said the boat is rated for a 40 to 60 hp motor, so it should not be overloaded if the motor is running properly.
the PB I posted for a 60HP Yamaha is kind of confusing sence it ways 60 but also says 70, but even on that 16' it called for a smaller diameter prop and lower pitch.
Gaha
Yeah, that's what I was thought as well. In theory anywhere between 300-400RPM.
Here's a performance test from Suzuki DF60A on Caravelle boat that weights over 1500lbs, with a bigger pitch 15. This is confusing as my boat weighs about the same loaded on a 14 pitch and struggles to get on plane.
Now this make me wonder if my Throttle body is fully engage when at WOT.
Is there anyone with a Suzuki engine who can look at how far there WOT on their engine?
Gaha
I don't mind loosing a couple of mph at top end, if I can get the boat on plane easier at lower rpm. Maybe a smaller diameter and 11 pitch prop might work better for my case when switching to 4 blades....
99yam40
I would test what you can to make sure the motor is hitting well on all cylinders.
the basics
Good Compression and spark,
and proper timing and advancement should be easy to test
fuel rail pressure also
if all is good then maybe cleaning and testing the injectors
lakensea
Since it's a fairly new engine, why are you even fussing with it. It is the installing dealer's responsibility to set/confirm the WOT, and make sure the engine is propped correctly. You should have signed and received a PDI (Pre Delivery Inspection) form from the dealer confirming both of these.
Gaha
Unfortunately, I live on an small island and don't have a lot of options. I bought the boat from a manufacturer and bundled the engine based on their HP specs. I wanted a Yamaha 60hp because we have a dealership here, however at that time they didn't have any available. I went with a Suzuki with the knowledge knowing that I don't have a dealership here. Hence why I am trying to get help here on the forum.
99yam40
Sorry I did not pay attention to it being a new boat and motor,
but I would still be contacting the ones that sold it to you to see what they say this rig should be able to do.
