Hello,<br />Sorry for the Suzy-fans, but i have had already many problems with it,bad starting,running with 19 pitch prop max 5200 rav's on 17 ft Abbate. This winter I cleaned carb's and jet's , checked reed valves( was oké).I thought I would find the problem but it was all oké(clean).first test was oké even better, few ours later only 3/4 throttle, full he was stalling
now, he won't push the boat, no power. it start good. sometimes a "sneeze". I renewed sparks,kill-switch, fuel line no extra filters anymore (pump oké),all sparks work and I have a compression of 9-9.2 bars(oké I guess)<br />Does anyone now the spec's for spark timing and timing in advance and by how many rav's???<br />The screws in front of the carb's, are they for the mixture air-benz only at iddle speed??<br />And what's the difference between the dt115 and dt140??<br />I've ordered a repair manual 2 weeks ago but it did not yet arrived.And it is now good weather here in Belgium
<br />Thanks already and maybe you've spared a suzi from the scrap
<br />Greetzzz from Belgium<br /> Tirett
