Got this engine a while back and it runs very well, changed the impeller and cleaned it up and cleaned the carb, Put fuel at a 50/1 mix and it run very good.
while I was trying to find out more about this engine I was told it runs on a 100/1/ fuel mix. this scares me to use this low oil mix, but when I had the leg off too clean up the crud in it I found a lot of carbon deposits in the ehaust port. any way i have started to go to at least a 70/1 mix. but would like to know if a 100/1 mix is right...help dont want to burn this engine up it runs too well.
