Suzuki DT 30hp Approximate year 1987 quits
Dude
The engine runs fine but after running around with 3 guys onboard it just dies. I punp the bulb and it starts up and will run great until it dies again after motoring in the bay for 10 or 20 minutes. Any suggestions?
deejaycee_2000
Re: Suzuki DT 30hp Approximate year 1987 quits
Ventilation at the tank, or time for carb rebuild ........
grid
20 minutes suggests pulling air somewhere in the system, regardless of the # of people in the boat. First, I'd re-check the fuel line; then back off the fuel pump from the block maybe 1/4", squeeze the primer bulb and see if gas shoots out the back of the pump. If it doers, time for a fuel pump diaphragm replacement.
deejaycee_2000
