Hi All<br />I want to clean out my oil tanks, filter and all the lines as a pm , on the block are two brass pluggs with an oil line going into and out of them. The manual and parts diagramms refer to them as check valves but i beleive they are oil bubblers. From what I have read here on Iboats they are supposed to introduce air into the oil line to break up surface tension and allow the oil to be drawn into the cylinder. I want to pull them out for a clean up but are they a press fit or screwed in ? Also are you actually supposed to be able to see the air bubbles , it doesn't look like they are doing anything. Suspect they are blocked.
