Old motor, in storage long time, It turned over nicely by hand without plugs when I got it. Oiled cylinders, new plugs, new tstat, water flow sensor, water pump, gear oil, carb rebuilds, new oil lines, new fuel pump, new fuel lines, new under cowl fuel filter,cleaned telltale, cleaned oil tank, used air pressure to blow out water passages and low oil and water flow alarms work on Suzuki monitor guage. Compression even at about 125, I do not have a leak down tester.
After a few hiccups it now starts and idles nice on the hose. I put it in the water and it will die at idle in gear. Goes in nicely and after about 15 seconds it slows and stops. Will not take gradual throttle increase, pumping bulb does not help. Sometimes will take alot of thottle and pick up speed. Where should I look for trouble? Carbs? Thanks MartyD
