Hi all, <br /> Can someone help me diagnose a problem? I have a SUZUKI DT 65 from 1987 (not the first owner), on a GLASTRON 144 boat. <br /> Got a problem from the beginning. The engine starts just fine (every time) and runs perfect at idle. With no load RPM goes to 7000, under load <br />RPM hardly increase to 2500, engine hesitates and if I insist it stalls. Engine starts on first crank, runs well at idle, but when I try again it does the same thing. BUT, only SOMETIMES, after many attempts, it works fine for a while (over 6000 RPM on WOT and full speed). <br /> History: last owner has changed: pistons (melted,overheated engine), CDI unit, water pump, gave up and sold me the boat including the roblem as a "bonus" at a decent price. <br /> I changed: new plugs, checking fuel and fuel line including rebuilding fuel pump <br />(classic fuel starvation symptoms?) , thermostat,temperature water sensor <br />(old one was melted)but nothing changed. Compression is 115 lbs/sqin every <br />cylinder,sparks looks OK, and pumping the bulb doesn't make any difference <br />(it stays hard all time) <br /> I have a SELOC Suzuki '88-'99 Manual and a Clymer Suzuki '85-'91 Manual, and there is no qualified Suzuki delear near by here in Romania.I'm new in boating but I have some good experience in car engines. <br /> Thanks in advance
