Suzuki DT 85 High Idle Issue
Hal Ray
Motor cranks and runs fine except for one big problem. When engine in cranked idles at 1500-3000rpm most of the time. However, there are times that idles perfectly. Choke seems to be functioning ok. Does not seem to be a problem with throtle linkage. Can change from high idle to correct idle from one day to the next without moving throtle or making any changes.
Wondering if there is some type sensor that could be causing. I have repair manual but have not been able to locate any obvious cause from reviewing.
Any thoughts would be much appreciated.
