Suzuki DT100 oil injection bypass
fshunt4lf
I have a DT100 oil injected OB that I want to premix and bypass the oil injection system. What all do I need to do?
stylesabu
Re: Suzuki DT100 oil injection bypass
leave it alone, you have to disassemble motor to remove oil pump drive shaft not recommended. are you having problems?
waffles1
Hi fshunt4lf,
Do a board search on your question and look at all the reasons not to remove this and see if you want to still do it. It's an extremely reliable system.
fshunt4lf
Yes iam haveing problems with to much oil mixture I think because it is flooding out and oil is dripping out of the carbs.
99yam40
Fix what is broken.
If you think it is the oil system then use your manual to do the troubleshooting needed and repair it.
Flooding is usually referring to the fuel system not over oiling
stylesabu
does the engine smoke when running? are sparks wet with oil? if not then you have an oil leak, not an injection problem as the oil isn't mixed at the carbs. the oil is sprayed in to air fuel mixture after the carbs, this is right out of suzuki manual. you have another problem
I have a 92 DT100 v4 that I just bought. The oil pump does not seem to work 100 percent. And the manufacturer don't make them any more. The motor starts just fine out of the water. In the water it will start instantly once I put it in gear it dies.
flyingscott
Start your own post this one is 6 years old. Why do you think the oil problem is the problem. I would look elsewhere for your problem not a oil pump issue.
