Marion Moore
- Joined
- Feb 6, 2005
- 200
Suzuki DT115STCLT #11503-651057 ? If I have read everything right the 651XXX means it is a 96 model.
Problem: On three occasions out of say, 8 hours of use spread over 6 fishing trips my engine has given an over temp warning. I was not running full speed every time this happened. After turning the engine off and idling for a few minutes it went away. On the last trip I reached back to feel the tell tale stream and it felt very warm. The problem is I have never really felt the water temp when everything was working fine so I have no comparison.
After the first occurrence I removed the thermostat, placed it in hot water, and watched it open then close after it was removed from the water. I checked the engine block temp sensor and it tested good with an ohm meter.
I was going to check the water flow indicator that my shop manual shows but my engine does not have one. It has a plastic plug in its place. The water pump was replaced about 15 hours ago when the lower unit was repaired.
Any suggestions?
Any suggestions?
