Suzuki DT115 Lower Unit
rcb130
Hello All,
I do not have serial and model number, all I have is the lower unit.
I am working on a 1991 Suzuki DT115 Lower Unit. Can I remove the lower shift shaft without pulling the prop shaft? If so,what is the procedure? Also, What size are the threads in the bearing carrier for the special Suzuki puller bolts?
Thanks in advance
rcb130
rcb130
Thanks to Brownspoint Marina. Prop shaft must be removed to replace lower shift shaft. Now all I need is someone who knows thread size of Suzuki puller bolts. I cannot believe no one out there knows the size or the bearing carrier puller bolts.
rcb130
