Have an issue with the motor shutting down going into safe mode and suspect stator/coils and/or sensors.
Idles perfectly but suspect the high rev battery charging coil is shot and is causing motor to go into safe mode when attempting to get on plane. Getting the "rev limit" light and "check engine" light.
So far i've checked compression (ok), replaced t-stats and water pump and put a new voltage regulator per a marine shop that checked it out and said likely regulator or stator issue. Still have same problem.
My Suzuki manual covers late 80's through early 2000's and the DT 140 EFI seems to be the odd duck. In the ignition and electrical systems section under DT 115/140 the wires/colors indicated for ohm checking the pulser coils, battery charging coil, condenser charging coil and gear counting coil don't match what i have coming out of the stator?
Does anyone happen to have the correct wire combinations/colors and ohm test specs to test this motor?
Thanks in advance for you help on this.
