planter box
- Joined
- Apr 12, 2003
- 1
Suzuki DT2 (0201 015840), leaked fuel from carb bowl & stopped running, carb cleaned blown out with air & float arm bent up slightly which stopped leaking, ran okay then stopped running & was hard to start, new spark plug, fuel etc & cleaned carb again, located small flake of crap above needle seat, too big to flow through, which was obviously blocking or partially blocking small hole above needle valve, unfortunatly played with oil fuel mix, can anyone tell me how to tune fuel/air mix screw on carb, motor is running but not quite right, bottom screw is obviously the idle speed...
