attowing@yahoo.com
- Joined
- Aug 31, 2007
- 40
Hi, I have a 2000 Dt200. I was out in rough Seas I took a hard wave the motor went under and shut off I took it back out on the water after being towed drained all the water. After that we went out and about half an hour of trolling I had two fast and one slow check engine light which means tps as per book. I changed. I still have the same light and only while throttling up. Do I have to reset the ecm and if so how with out scanner? Or is it a special was I have to do the tps?
