Suzuki DT225 Trim Problem
jonjar2
hey guys<br /><br />i have a 98 suzuki dt225....replaced the trim motor about a year ago, so it shoudl be good...and all of a sudden, (it's down in the water right now) the motor won't go up or down. When I press up or down on the side of the motor it just clicks, no sound from the motor. Could both relays have gone bad at the same time or does that sound like the motor crapped out or what?<br /><br />thanks
deejaycee_2000
Re: Suzuki DT225 Trim Problem
Hi, I will start by checking the basics first, make sure that your battery is fully charged, and then make sure the battery terminals are on tightly and that the wires are on properly. The same thing happened to me a while ago and I took the whole thing apart, where at the end it was my battery terminals that were badly damaged and needed to be replaced. good luck
