Troutboy NZ
- Joined
- Apr 24, 2007
- 32
After some running issues, I replaced the throttle position sensor and she is running ike a dream!!! Just purrs and so smooth - has as much go as my previous Merc 40hp!!! A few problems though - when I give it the gas all the way to full throttle, she revs right up there - it does however seem to flatten out with no response in the last 1/4 of the remote? Is this normal.
Also do I have a rev limiter, and when does it cut in? - I don't have a tachometer, but after I gun it right to the throttle stops, it will run fine for exactly 10 seconds then the revs drop to what I guess is 4000rpm - it would not be lower - I presume this is the rev limited cutting in because I am over revving the engine??? Will a higher pitch prop help.
Still have the bloody red LED light lit on the engine cowling, and I have eliminated everything it could be I think - short of the CDI - is there a reset on this 1995 engine? All ther sensors test fine as does cooling, oil etc. It just will not go out, it is there from the minute you flick the key until you turn it off - with no alarms though. I have also tested the alarms and they work, just this red light is haunting me!
