Okay, the clutch rod bolt broke on my DT4 outboard. Had to sail back into the slip! Anyway, I pulled the motor, dug out the broken clutch rod bolt and connector parts, and replaced with new parts. Problem is I don't really know where to set the clutch rod connector and don't remember the position of the F-N-R lever at the time of failure. I tried a few settings and the prop doesn't seem to spin with any significant power. Also now when the motor is running, it looks like some water/air bubbles are coming out from the clutch adjustment plug (big rubber stopper). Any advice or suggestions most appreciated since my girl is expecting to go sailing this weekend!
