Al Mottola
- Joined
- May 1, 2005
- 36
I have a '87 DT55 which I purchased a couple of months ago. It did run then, but not well. I checked everything over and it did start and ran fine with muffs. Recently, it was hard to start, but it did finally start. I turned it off, and now can not restart it. It has spark, new fuel, and the chokes operate normally. I have sprayed starting fluid into the carbs, and it will not even pop! The compression on all three cylinders is ~ 140 PSI and the timing on cylinder #1 while cranking is 10 BTDC. What am I missing?
